The 'Y' shaped jobber on top of engine....?
(In Topic #74580)
ops: ops: ops: ops: ops:
Its just i'm having major cold start probs at the mo and it looks like the bottom half of it is slightly melted, wondered if it could be the cause.
I know theres that list of things to do, but am changing engine soon, as long as the starting (air) system works fine i can use it on the 16V, but am having similar cold start probs with the 16V so need to resolve one of them!!
Dave
Is my question really that stupid?
If you take it off, clean it, ensure that it's not melted through, and then put it back, again ensuring that all the pipes connected to it are sealed to it properly, then you could eliminate it as the cause of your cold start problem :dontknow:
Hope this helps!!!
Regards its condition, any damage that would cause a leak in the system is going to be problematic. Not sure if it would cause cold start probelms.
1983 1100 C
1983 1100 C
If your's is leaking, you may have cold start issues, as the extra air is weakening the mixture.
Its not just a starting problem:
-once i've got it to catch it cant maintain revs, or does so very lumpily, maxing at a normal level just under 1000 and dropping and coming back up. In fact giving it any throttle tends to make it cough and die! It'll do it seemingly randomly for a good 5-10 mins. When I bought it it was always a bit slow on uptake, ie not smooth from low revs, has been getting steadily worse. I'll drive down teh road fine, then go to accelerate from a junction and it will go low and rough/lumpy again.
I'll try your method Rich to see…When starting at the moment I normally let it turn twice or so. stop then try again, takes a good 10-15 tries, then it'll revs up to 1000, and go lumpy, then settle fine. then i add throttle and it goes lumpy again.
ARRRGGGGHHHH
I didn't want to spend any effort on the engine as i'm taking it out 'soon' anyway, but I dont have time for another month now
And now i've got a rythmical noise coming from front..not good. Hoping its related to the silly camber i've been running. Oh and exhaust is blowing like a cheap ho, but thats just a dodgy C clamp.
As always, cheers for your suggestions guys…
