still won't bloody start........
(In Topic #132890)
these are the symptoms.
its a 1.8 gti
turns over starts and dies pretty much right away, if you keep the engine turning over it will not start again.
remove the spark plug and it still sparks fine, tried a new module too, and my module on a friends car, all fine.
could it be the fuel pressures?, vacum? any ideas would be greatfully received
Check timing
Check compression
could it be anything to do with the warm up reg, or 5th injector??
this is defo fuel related, if you squirt easy start into the airbox, it runs.
a few weeks ago it would drive for a few minutes and then start to what seems to be a misfire, then die., give it a couple of mins, and it would go again. don't know if this has any relevence, but my brother tinkered with the old metering head and it never run again, not that it ever run properly.
how's and where is this done?? any tips.paul_c said
You need to set the mixture properly after replacing injectors, or metering head. Until you've done this, there is no point replacing any other components. Indeed, your old injectors or metering head are probably okay, just needed to set the mixture.
http://www.vwgolfmk1.org.uk/modules.php?name=Content&pa=showpage&pid=42
