starting problems
(In Topic #115883)
starting problems
hi, 1600 gti is been a pain starting. it will start but takes a while to fire up. but on occasion it will fire up straightaway. any ideas ?
phil
phil
1981 1600 gti was silver now mars red!!
<a href="golfsig.jpg picture by barty2 - Photobucket"><img src="http://i286.photobucket.com/albums/ll82/barty2/golfsig.jpg" border="0" alt="Photobucket"></a>
I'll assume starting from cold - if its starting from hot, let us know. Easy check - unplug the 5th injector. If its the same, then suspect this, the thermo time switch, or the associated wiring.
cheers paul. it seems to do it both better when warm only slightly. i was thinking 5th injector i need to check tomorrow.
if from stone cold it could be down to the wur, but ideally you need to get it on a set of pressure gauges to diagnose the problem one way or the other.
Mine does this. Starts fine in the evening if its been used in the morning. But, start ot in the morning from cold, bad starting, poor running until after 2 or 3 miles, then its fine. :dontknow:
Website Manager
You can add me to this list too.
MY80 GTI | MY07 GTI | MY10 S3
Hi, I have a similar problem with my cab 1.8 GTI.
From cold It takes about 10 seconds of cranking to start, then takes a few minutes to warm up and the revs to settle. It then runs perfectly.
When the engine is hot it starts first time. When I unpluged the 5th injector (cold start valve) it started first time. What does this indicate?
Any advise appreciated.
Worth checking the power going to your starter motor with a multimeter. Try cleaning your earths if you haven't already.
I have a similar problem with mine. Does seem to start fine when hot though.
Chris2k004 said
When I unplugged the 5th injector (cold start valve) it started first time. What does this indicate?
I had exactly the same outcome. Fired up straight away. Anyone got any ideas?
I thought it might be the fifth injector making it over fuel on start up.
