starting a 16v for 1st time after conversion
(In Topic #155427)
i know it turns over and has oil pressure because i tested it with a battery before i put my loom in
now my loom is in and nearly all wired up, the airflow meter is not connected does it have to be to get it to tick over ?
when i turn my key i can hear a few things clicking around where the fusebox and ecu is but nothing happens, all fuses are fine and earths are good, all i want to do is to get it to tick over
is there a check list i should follow ? do i need my air flow meter connected ?
this is my 1st conversion so don't know what is required at this stage can someone please help
thanks
tom
Last edit: by bowskill
thanks
tom
Whip a plug out and check for a spark, take your bottom fuel line off and check fuels getting threw when you turn it over. If you've got fuel and a spark it should run.
i thought there was only one on the engine, on top of the rocker cover ?
when i turn the key the plugs spark and can hear fuel pump kick in (no fuel in tank though)
will check all earths again tnite and try again
any more ideas if its not the earths ?
going to try a different fuse box see if that works
if your not going to say something to help me don't comment !!!!!!!
i don't want your help if your going to talk like that to me
On turning the ignition on, a short pulse (about 1- 3 seconds) is sent to the fuel pump to pressurise the fuel rail. Once the starter motor starts to turn the engine, a 12v pulse is fed back to the ECU from the negative side of the coil. The ECU then turns on the fuel pump and energises the fuel relay that provides a fixed 12 volt supply to all the injectors. The transistors in the ECU start to ground the injectors with a longer pulse than the normal idle pulse for about 3 seconds. This provides enough fuel to start the engine and should then allow the engine to tick-over.
Some other things that may affect tick-over include:
Correct air / fuel ratio
Perfect Ignition / burn, i.e. faulty HT leads, distributor cap, rotor arm, ignition amplifier, coil, plugs etc.
Ignition timing
Hope that helps!?
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
Sticker Pig
i only want to turn the key and get it to crank over, not start
The battery is dead
The wires connecting the battery to the started motor are corroded
Corroded or poorly connected Earth somewhere
Faulty starter motor
Also as said before get some clocks in it, turn the key to the first position (not all the way to start it) if the red warning dash lights don't come on (and the battery connections are ok) chances are your ignition switch may be faulty
Moisture inside distributor cap, if so clean it out with a clean, dry cloth
