sporadic starting
(In Topic #132071)
sporadic starting
Its fine on shorter journeys, but if for instance i go 7 miles out of town and need to get fuel to continue the journey when i fill it up, it just wont start. Just a clicking from a relay (got 17 on it and is very warm to touch) and no engine turn. If i then leave it for 5-10 mins it fires up fine and runs like a champ.
I have checked all connections to the starter (i replaced the starter two weeks ago) and it has a new battery.
Could it be the relay at fault?
Its driving me nuts.
cheers K
It could also be the ignition switch. To check this, bridge the large round terminal on the starter motor to the solenoid's terminal, if it works fine then, its the ignition switch (or something similar).
Does your car have an immobiliser?
Will bridge it tomorrow when it packs up again.
It does have an immobilsiser.
Thing is, why would the switch not work after a medium length journey only?
Surely when im driving the "start" terminal is just dormant? (not that i dont believe you, just trying to get my around the bloody issue)
Are there any earth straps i should be investigating?
