Small Knocking Sound
(In Topic #86169)
I replaced the timing belt everything back together and she started. The engine seemed to be running fine.
I then proceeded to replace all the filters and the oil. I then ran the engine up for a bit while it was running I could hear a small knocking sound. It sounds like its coming from the top of the engine.
The knocking sound is not consent it comes and goes. I have not had chance to re-shim the new follower I am using the old shim could this cause this noise I would have thought it would have been move of a tap than a knock.
The car is 1.8 GTI CAB with a DX engine
James
1987 Golf Mk1 GTI 1.8 Cabrio
Any idears?
James
I had a similar problem on my camper, it was a small knocking from the top of the engine, it turned out to be a valve guide. Basically a small copper tube had worn, meaning that everytime the valve closed it didnt seat correctly causing the knocking sound.
Hope this helps. Mark.
when the noise is present is it rev specific?
any loss in power / misfire / backfire?
i think marks right about the valve guide, either that or a slightly bent valve perhaps.
rebuild in progress....
The car has made a couple of backfire's since this happened never did befor i touched it.
Is there anything you can to see if the valves maybe bent without taking the top of the engine off?
James
I've got a similar problem after part rebuilding my DX engine for piston ring change - tapping from one cylinder top end. I did a fairly basic job, and didn't strip everything - just head off, sump off, pistons out, new rings and all back together.
I thought tapping was due to a broken ring, but it looks likely that it's a valve touching the piston!!! Compression is now excellent, but valve clearances are all too tight -especially exhaust valves. Peeping in the spark plug hole I can see a shiny patch on the edges of the 'cutout' in one piston…so this weekend it's a reshim job and hope it cures the problem without damage!
I know I should have checked the tappets, but…you know how it is…
Worth considering for yours!
Best measured when the engine is warm…
http://www.clubgti.com/forum/showthread.php?t=107003&highlight=hydraulic+dx
and as yours is an 86 and the changeover was in 85 you do have a hydraulic head ok!!
Anyway, confirmation that later DXs have hydraulic tappets…
The knocking noise occurs once the engine has warmed up when it cold there is no noise but it seems not to run so well.
The engine makes quite a severe rattel/knocking noise at about 2000rpm then it seems to be less but still very present above that.
James
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
I've had the camshaft out already since i had to replace a damaged tappet bucket.
At the same time I also did the timing belt twice. The first time i did it, it ran but not well at all. Then the second attempt was much much better. But now i have the knocking.
The timing was out on the engine for a littel bit is it possible that there could be damage to the valves? if so how can you check?
Its likely that ive made some error in doing this. Which is causing the engine not to run so smooth and produce this knocking when warm. I think the engine could do with a flush would this mean replacing the oil since ive only just put in a fresh batch?
James
Are you sure the knocking is coming from the engine???
Yeah im sure its coming from the engine i think the its from the top half but its so hard to tell.
Thanks for the advise guys.
James
