Small groove (hole) in inlet manifold?
(In Topic #73841)
Do you have a picture you can show us?
My Build Thread
Sorry about the size. ops:
1983 lhasa green GTI
1982 lemon yellow CL
1983 1100 C
1983 1100 C
Checking the VW parts drawing, there also seems to be a mark where the hole should be.
Strange.
turbtechnicsMK1 said
Got one on mine. slightly bigger though. Have alway thought it was there as some form of drain hole in case the manifold webs/tracts got water or some from of other fluid on them for some reason and it needs to drain the fluid to the ground rather than just leaving it there :wink:
That's a good idea, BUT, there is only normally a hole between inlets to cylinders 1 and 2, plus, it would not drain to the ground, it would dump it on the exhaust manifold!
Agree with the majority though - casting imperfection - not an issue.
My Build Thread
