Running problems with 82Gti cabby
(In Topic #99055)
you want it idling at 850 when warm, once thats set then we can advise you a bit better (thats if it doesnt sort the problem out) :wink:
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
most common cause of idle "hunting" and drop in idle is an air leak somewhere (it wont cost a penny for you to check and it only needs a little leak to cause issues), and there's no point playing around with mixture yourself - without the proper tools you'll just be winging it
check the above, listen out for any hissing/air leaky sounds and hunt them down and try n deal with them, if you still have the problem take it for a tune.. but make sure there's no air leaks otherwise whatever work they do will come to nothing - everything needs to be spot on before hand :y: otherwise you'll end up being charged for something you could have done yourself :wink:
check inside your dizzy cap and rotar arm for wear (pitting and build up around contact surfaces), also the contition of your spark plugs and HT leads
all can leave a smell of unburnt petrol as well as dodgy idle
once all thats elliminated, if the exhaust fumes smell rich (eye watering, quite litterally) then take it for a tune, please dont wing it, its almost an art to get right (along with timing) without the correct tools
