running on 3 cylinders when cold?
(In Topic #75704)
Steve
Then swap the HT's to see if the misfire moves onto the cylinder to which you move the suspect HT. If it does then new HT's if not then possible fuel injector/engine issue. When you swap the HTs swap at both distributor and cylinder head end and maintain the firing order 1342 (follow leads back from cylinderhead left to right). Might help to mark no's 1342 on the distributor cap.
1983 1100 C
1983 1100 C
Could it also be an injector seal? is there a way of testing if an injector works?
cheers for your help
Steve
Not sure if old seals would cause his problem, you can change the injector seals easily and they only cost a couple of quid for four new ones. Best way to test injectors is to follow Prowlers injector test
1983 1100 C
1983 1100 C
Secretary
