running issues!
(In Topic #104228)
running issues!
when were the ht leads last changed, pull them off and have a look at your plugs, check they aren't black.
this would be the first things to check cause they pretty simple to diagnose.
if they're ok it will be a pressure, problem or an air leak. hth
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
A mechanic diagnosed it as my fuel metering head, so i changed it and it didnt make any difference. I ended up changing my pump, accumulator filter none of this helped. untill eventualy i changed the injectors and it went like a rocket.
Basicly i think it could be any part of your fuel injection system.
Having said that i would check your spark leads dizzy cap and rotor first cos its cheap. like lakesk8 said
daaarg
woZa said
Sounds like a fuel delivery issue to me. Search for Prowlers injector Test. Give that a go & report back…
If you had done this test at the start then you could have saved yourself a lot of time, effort & money…
vwgolfm1 said
hello just a update of what i have tried i have changed fuel pump, fuel accumulator, metering head ,plugs ,leads dist/cap ,timing/cambelt done alternator, capacitor, fuel filter ,vacuum hoses and still the same problem the garage was no help what so ever so im going to put it on a trailor and take her to the nearest vw specialist, i think its time to get someone who knows what their doing on this one lol, if anyone has any ideas atall on what this could be im guessing its going to be the injectors but ill keep you posted thanks for all the posts.
x2
Looking back though, its been to a garage - I'm sorry if this is another moan but it really narks me off, that there are garages out there, taking money off people, who basically mess around and can't troubleshoot/fix cars any more! K-Jet, yes its mechanical, but in the era so were half the fuel injected cars out there so its not exactly a rare or weird setup!!!!!!! I'd be tempted to take a large fish with you and ask to see the mechanic who worked on your car in person……
