replacing cylinder head
(In Topic #103564)
It's not a particularly difficult swap - there's plenty of room around the engine, so most of the bolts on the head you need to get to are accessible.
Be prepared for a few sheared exhaust manifold studs - I'd arm myself with a new set of them for the replacement head, plus some nuts, if you haven't already done so.
A new set of gaskets (inlet manifold, exhaust manifold, manifold to downpipe, and a head gasket (obviously)) is also a good idea.
Here's a link to my resto thread where I changed my head gasket
HTH
Rich
thanks dean
deanosupremo said
ok got the bits, welll still need a cylinder head as of… but does anyone know the torque settings for the head bolts???
thanks dean
They're normally printed on the packet, of a new set of bolts. But they'll be in Haynes manual too. I believe its an initial torque followed by a 90? turn all bolts then another 90? turn on the bolts (they're stretch bolts and can't be renewed). Also it has to be fairly accurate - I've heard stories of people going slightly over the torque required and snapping a bolt.
Dean
12mm socket head
Stage 1 40Nm or 29lbft
Stage 2 60Nm or 44lbft
Stage 3 75Nm or 55lbft
Stage 4 Tighten further 1/4 turn
10mm socket head
Stage 1 65Nm or 47lbft
Stage 2 Tighten further 1/4 turn
Hope this helps
Tim.
thanks dean
