removing oil cooler on mk1 gti 1.8
(In Topic #123542)
i need to remove the oil cooler of a 1.8 EV kjet as i think its the culprit of my water oil mix.
all i need to know is how does it come off?
do i need to remove the flange from the block?, or does it unwind from the flange?
rich
mk1 caddy
mk1 golf gti cabb
mk1 golf gti cabb
now i presume you have the water cooled "oil cooler".
and i think the whole thing is held on with three allen key bolts, and the two water pipes.
but like i said, i might be wrong!
The 3 allen keys hold the housing to the block, but there's no need to remove it, in fact I don't think you can reach the bolts without removing the cooler.
paul_c said
Its a 1" nut underneath, ie where the oil filter screws onto. Then also you'll need to disconnect the coolant pipes.
cheers paul, i need to remove mine to put on an air flow oil cooler
