really rubbish idle/start up
(In Topic #76137)
When i try and start my car in the mornings it goes, only just….Then, whenever i have to stop for some reason, if i dont rest my foot on the accelerator a little it will stall/idle rougher than a badgers ass.
Im guessing that this is'nt the norm…SO what can i do to sort it out?!
Many thanks!
what's the running like when you put your foot down? any hesitation or spluttering?
:dontknow:
does it start ok once warm? even after say 15-20 minutes? or still the same?
drove to swindon to pick up some new wheels yesterday, loaded them up, restarted and she was fine, so its ok at restarting when she is hot, but still idles really badly, very lumpy and vibrates a lot..
you can tell that she is a woman, treated her to a new set of wheels, and she is still not happy!
Have you thought of a name for yours yet?
I think they're never happy
not entirely sure what's causing your problem though but it might be worth adjusting the idle control screw on the back of the throttle body, a little turn out should raise the idle enough
be worth checking for air leaks too IMO
Is there a certain procedure with the idle control screw, or do i just do it? Being rather dense i dont actually know where the throttle body is…any pointers?
got some wheels which are in need for a refurb, but are pretty cool, or will be….bbs stylie, gona have black centre's with a polished lip…
throttle body is on the right-hand side of the inlet manifold.. follow the black pastic tube from the airbox by the battery and it's at the other end of it (if that makes sense??).. the idle screw is on the back of it.. 7mm spanner IIRC (which is bad considering mine fell out and had to replace not so long ago ops: )
If your at the Berkshire meet on wednesday I'm sure we'll be able to give you a hand and/or pointers :wink:
Will have to have a poke around tonight with a torch and a spanner in hand, and hope that it solves my problem…..
wednesday should be cool….
see you wednesday
