Radiator fan not kicking in....
(In Topic #96473)
What is the fuse position to check? I will check them all but so I know where to concentrate my efforts.
And then are there any usual problem areas to check?
The car is a 83 gti cabriolet
Thanks in advance.
crag
does the fan run if you put 12v to it?
check the thermo switch in the rad to see if thats working. remove it and put it in hot water with a multimeter across the terminals (i dont mean all in just the end of it)
(At least I think it's that way around!) :wink:
here for a good time, not a long time
What's probably happened is one of the connectors to the switch is corroded or loose. If not, then suspect the switch itself.
