Possible sticking thermostat?
(In Topic #134859)
Both the oil and water temp are high. Oil is sitting over 100 when i would expect it to read about 70 -80 and the water needle is hovering around the warning light (which dont work!). The needle is moving no further than clearing the light on either side. I have hot air blowing in the car and the car was driving fine.
My radiator has now cracked at the top hose while i was squashing pipes to check for wat / air. i think this is more a result of than a cause.
What would happen if the thermostat was stuck shut?
hows it going?
yip sounds like your thermostat is stuck shut , I would be checking it first .Put it in a pan of hot water should start opening at 87deg i think , the opening temp will be stamped on the thermostat .Make sure if it does open its at the correct temperature
baz
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
If the thermostat was stuck shut the coolant pipes top and bottom of radiator wouldn't be hot to the touch.
another tip is the bottom hose on the radiator should start getting Hot just before the temp gauge reaches the half way mark.
baz
Think i need to give the electrics a good overhall! those gremlins seemed to have multiplied this year
