Popping metering head.
(In Topic #100526)
As a side note, the fuel pump wont run unless i run a direct feed and bypass the ignition etc. Should the pump run continually, or does it just run when it needs to pressurize the sysytem?
I'm fairly new to Golfs, so excuse my nubbin questions :?
also the fuel pump should really be run off the relay as this way it only runs when the engines turning over.(it runs all teh time and any unused fuel is returned to the tank)
Life Member
if that makes sense! basically when you remove the outer cam belt cover you are left with a half of the cover between the pulleys and the actual engine. on the top pulley there are two marks, one 'dot' on the outside and one 'dot' on the inside closest to the engine. when number 1 piston is at the top of its combustion stroke the dot on the inside must be level with the top of this inner cover right next to the top edge of the head. theres a guide at the top of this section of the forum to setting it with photos.
