PLEASE HELP!
(In Topic #90688)
PLEASE HELP!
I sooo hoping someone out there can help me.
I have a GTi Cabrio and when i start the car it will run fine for about 20mins the splutter and die.
If i re-start it it will run for a further 5mins then splutter and die again.
I have changed the -
Plugs/leads and dizzy cap.
Metering head
Warm up Regulator
Fuel pump relay
Anyone got any idea's?? Im at my wits end here….
HELP
Thanks,
Jez
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://i214.photobucket.com/albums/cc78/jezzle31/mygolf.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
wouldn't want to get pregnant!collo16v said
Have you checked your coil? :dontknow:
has it just happened? has it got progressively worse? is it the mild mannered janitor?
I have had it in a garage (over a week)and they said my car was under fueling.
(dont know how much of that is true)
To be honest the garage its in at the moment i think they dont have a clue whats wrong with it.
Im hoping one of you can help me out,
have you tuned the co since changing the parts? it sounds like fuelling.
It does seem to be when the engine gets hot it cuts out.
As it runs for longer on tick over but drive it and it will cut out
Tune the coil over?? is this something that needs to be done when changing parts?
Sorry im pretty new to all this and only know what the Mechanic told me.
Thanks for helping mate,
Yea it was running Lean and have now fixed that problem but it is still cutting out.
Do you think we have missed something?
jezza31 said
Hi Paul,
How are you now sure the mixture is correct? It doesn't sound like ignition, after all it runs fine when not warmed up, in the first 20 mins…..
MP
jezza31 said
The Fuel was running very lean 0.5bar now it has been increased to 3.5 bar so we know its not running lean anymore.
What part of the fuel system did you measure??????
jezza31 said
Unsure mate, this is what the mechanic told me.
Get another mechanic to look at it, then.
I have just joined the AA so i can get my car towed back to bournemouth, and then i can see my regular Mech.
Hopefully he will be able to find what the problem is.
Found out i have debris in my tank.
anyone know of how to get it out without having to remove the tank.
I have heard you can stick a big magnet to the tank and that solves the
problem…any truth in this??
thanks,
jez
