please help guys
(In Topic #79255)
please help guys
Check that the induction hose is not disconnected - this big hose thae goes from the metering head to the engine.
If OK do prowler's injection test - found at www.vwgolfmk1.co.uk and report back with your results.
Rich
Do the test. It's not to check the injectors but to see what happens when you try to do the test. Report back. Your results will enable us to diagnose your problem more easily.
Also check the cold start valve (5th injector) is operating correctly.
Rich
Rich
but just because the pump is pumping doesn't mean its the rite pressure.
Regards Volkswarren
better but idle high now
one more question though. when warm it seems to idle too high! doesnt seem to be the 5th injector as i tried removing this. any ideas? Jon
