PISTON RINGS (HELPPPPPPPPPPPP)
(In Topic #85006)
OLD IS GETTING IN TO THE AIR FILTER CAN ANYONE HELP ME OR ADVISE WHAT THEY THINK MAY BE THE PROBLEM.
I WOULD BE GREAT FULL FOR ANY HELP OR ADVICE
THANKS
BEN
NEW MEMBER
Oil in the air filter is not uncommon though. How much oil are you seeing?
My Build Thread
Black Cabby
Can be cured by taking off cam cover and cleaning crud out the layers of the mesh filter -but this does mean breaking the three spot welds which hold it in place….no problem if you can weld them back, but I've managed with three bolts, which does the job but doesn't look so pretty…
Tired Piston rings will add to this problem by increasing the amount of fumes being forced up through the mesh filter, so this may also be part of the problem!
Bert
Bert said
what engine? big block or small block? the small block are prone for it,renew the crank filter at the back of the block where the rubber pipe comes from to the air filter,et volia thanks for coming. :wink: Also oil and filter change.
Bert
I have small block 1272 ccm and having a same problem,but i have renew my engine. I have put an Oil catch can,so the oil is being catch in it.
2.0 16V
