Pintle Chatter
(In Topic #114017)
Pintle Chatter
I've come to the conclusion that the metering head is at fault because its very hard to lift the pan and after closing it takes along time(5-6secs) for it to stop the fuel.
However I notice that I wasn't getting the expected high pitched sound from the injectors (Unless its so high I can't hear it). I am using a set of new injectors from Crazy.
So I thought I'd try the original injectors and they did make the expected noise.
I also noticed that when I did the test with only 1 old and 3 new, the only injector to open was old one.
Anyway I've hopefully sourced a new metering head but should I be concerned about this lack of chatter?
Thanks in advance
James
1987 Golf Mk1 GTI 1.8 Cabrio
