over fueling pls help
(In Topic #136691)
@ last got my blue cab on the road, bit lumpy driving ti to garage for mot but i made it, when they tried to set it up on co2 machine it was running way too rich, they tried for ages and couldnt understand why its over fueling, can you help pls
1983 1.8gti cab
also u know the device that normally sits on the airflow on the corner mine hasnt got 1 … would this cause the problem?
There are a few other things which can cause too high mixture, the main one on a K-Jet car is the fuel pressure being wrong; but blocked air filter or induction pipework might also play a factor.
I am guessing you don't have a fuel pressure gauge? Does the garage…..???
2) is there suppost to be an earth strap from the coil to rocker cover , if there isnt one will this make any difference?
3) i have a poor spark… sometimes on turn over its like having a flat battery
4) on the top section of the metering head there is a device that has a pipe coming off it and heads towards inlet and has electric plug that goes into it , well on mine its not there the other pipe it blanked off and there is no electric plug anywhere on the loom for this to fit .
5)its miss firing, had pressure check done and when it does actually tick over its not too bad
all help very much appraciated i dont want to sell or strip it , i took it for mot and it only needs wheel bearing,brake pipe
plenty of infos on here about testing the injectors so get searching
vw did not put those parts on for a laugh no offense ment by that,
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
since_1983 said
why dont you let the garage deal with it m8, as paul and someone else pointed out its guess work and and to be fair if you know you got bits missing why are you asking if that makes a different,
why …… cause money dont grow on tree's …. also i asked if it should be there for a reason, as it turns out mone didnt have one,any way i fixed it now , replaced the following ……. injectors, all injector pipes,dizzy,wur,metering head,plugs, job done!
