oil warning light when cold
(In Topic #108898)
any advise would be of help chears deanos
As you just rebuilt the engine then it is possible a small piece of crap got itself stuck in the high pressure switch, that is the one which sets off the light & buzzer. It is the one located on the oil filter mount and you could test the wire there for a break also. The instrument cluster has an oil warning system mounted inside and they have been known to go bad from time to time. 2000 - 2500 RPM is when the warning system will trigger the light and buzzer if it is bad, or you have a real high engine speed pressure problem. So if the wiring and switch are OK and you know you have good pressure, only way is to test it, then the dynamic oil pressure warning system is defective.
