oil question
(In Topic #77440)
oil question
Can anyone help.
Cheers,
Ross
There are 2 types of gasket so make sure you get the right one. The original on your car will be a cork one but it could have been changed to a rubber one at some point which means that the studs in the top of the head will have been replaced with a slightly different type, this means the cork one will no longer fit.
oil question
oil problem
Matthew
oil problem
But then it was full of ash :cry: :cry:
So I chiesled the thing open from inside, drilled out the spot welds holding the mesh togther, cleaned up and re-weld it all back togther.
You could try soaking in petrol/solvent or if you want an easy life most people buy new ones, (complete cam covers)
The advantage of a toothbrush is that you can poke it in through the breather exit and shift the gunge from the inside. (the angled head ones with the pointy out bristles are best - but make sure that the toothbrush is genuinely surplus to requirements…. :mrgreen: )
If you're planning to do this, I'd also recommend investing in a cheap plastic wash basin to catch all the crud that comes out. Otherwise you'll change the colour of wherever you're working to a deep chocolate brown colour.
Bear in mind that the mesh doesn't need to be completely clear for the breather to do its job.
AliCabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
