oil pump change on 6A
(In Topic #138921)
Hi,
I have a 2.1 6A block fitted with a deeper Shrick baffled ally sump, its too low so I want to change it to a shallower KR one.
I am a bit confused concerning the oil pump, do I have to change the oil pump or will it be okay?
thnx in advance
thnx in advance
do you know if anythign was done to the oil pump? becasue if not then it'll be fine. i dont know of any oem fit pumps with a deeper pickup that work with a std mk1/2 sump. worst case you will need to change the pickup, not the pump though
