Oil Pressure Problem
(In Topic #149599)
I have checked:
1. The oil pressure with a gauge - fine.
2. Both oil pressure switches - operating correctly.
3. Voltage on wires to oil pressure switches - 12V present on each when ignition switched on, nil when ignition off.
I have inspected the back of the instrument cluster and flexible 'printed circuit' wrapped around the back. All the conductor tracks seem OK. The Haynes wiring diagram refers to a specific oil pressure relay J-118 but I can't find this. All the instrument functions work except the 'Change Up' light (and the oil pressure alarm!). To fix other electrical problems I have renewed the relay/fuse board.
I have seen reference elsewhere to 'an L-shaped printed circuit (PCB). Is this the blue plastic sheet with copper tracks? Is this where the alarm logic lives and are they available anywhere?
Any ideas?
Thanks for your help so far.
