oil light flashing
(In Topic #96364)
oil light flashing
weather its warm or cold, Driven hard or normal. The oil pump, Pick up pipe and both oil preasure sensors have been changed too. Im thinking possibly wiring fault bad earth or possible wrong oil preasure sensors have been fitted, is there possible differances between them? The oil preasure has been checked and its fine its just a bit annoying when your driving it… Can any1 shed any light is it a common problem Thanks ian
Other thing it's worth doing whilst you are at it is to clean up the oil breather gause in the rocker cover as this can get carbon deposits stuck in it. Once blocked the oil pressure will go through the roof and you can even get oil coming up past the dip stick tube.
