Oil Light at speed
(In Topic #96612)
Oil Light at speed
I'm not sure whether to start worrying about this. What do people think?
The last few time I topped the oil up I used part synthetic. Not sure if this could have anything to do with it?
Any ideas?
give her a good oil and filter change and check the connections are good on the oil pressure and temp sensors. then see how it is.
<a><img></a><a href="Login to a private Photobucket.com album
All the conections look good. The sensors are quite new as well. Gonna do an oil change anyway and see how it goes.
Was thinking about fitting a set of VDO gauges. Anyone know how easy they are to sort out?
DubPartz
Me too… Dont suppose you have the part number for the oil pressure sensor / photo do you… called in at GSF Liverpool today, the guy said there are a few different parts, non e of which give the engine cc or codes? He said i would need the part number.DubPartz said
I've had a very similar issue recently. I would start by changing the pressure switch on the RHS of the head. It worked for me
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
Assuming your engine has oil and hasn't yet started knocking, most likely causes of oil lights/buzzers are in the warning system itself.
1) 2 seconds after 2000 RPM or more, light and buzzer come on, replace the high pressure switch.
2) Oil warning light on at idle, especially when hot, replace the low pressure switch.
3) No oil light blinking with key on, engine off, replace low pressure switch and/or repair light in instrument cluster.
4) If these quick tips fail to address oil warning light/buzzer issues, do not pass go, head immediately to your nearby mechanical oil pressure gauge store and buy a gauge. Buy or make a 10 x 1.0 mm threaded adapter. Test your oil pressure, cold and hot. Know what you are looking at.
83 Mars red GTI
83 Mars red GTI
83 Mars red GTI
Oh the joy of driving the MK1 without the horrific sound of the oil buzzer!
83 Mars red GTI
