Oil Leak Problem
(In Topic #92259)
Oil Leak Problem
Hi there guys ,
I've traced the oil leaks from my engine and after opening up the timing belt cover , there's plenty of oil stains , my question where is the leak coming from ? blown headgasket , block seals , oil pump ? here's a picture of it .
Looks like someones already tried sealing the rocker cover with about 2 gallons of sealant :dontknow:
Fit a new gasket, whilst you have the cover off check the breather isn't full of crud. They get blocked and oil is blown out everywhere else.
leak
i had the same issue, try replacing the camshaft seal.
solved it for me.
solved it for me.
here for a good time, not a long time
I have that problme but about 3 times worse its covered all the timing belt and its dodgey as anything....i dont know where mines coming from? its covering the wishbone and the driveshaft also!
Mark 1 Golf GTI 1982 1.6 owner!
Mark 2 Golf GTI 1986 owner!
