oil leak need help
(In Topic #121825)
oil leak need help
Hi folks,
1st i have an oil leak were the filter houseing goes on to the block anyone know were i can get a new gasket?
2nd another oil leak… the sump nut at some time has been over tightend and damaged the thread is there anyway of repairing it or is it a new sump?
1) vw should do the gasket, if its obsolete for the mk1 order one for a late mk2 golf as it will fit just the same
2) new sump is about £30 tops so be easier and cheaper to just fit a new one and be done with it
Cheers smokey :wink:
If you want to go to town you can also upgrade the sump gasket to the rubber item at the same time or fit a windage tray which has the rubber gasket as part of it but you will need new bolts to hold the sump on if you do this
Got a windage tray on mine and its been nothing but trouble.
The rubber around the edge is harder/stiffer than a regular gasket and it can be a problem to get it to seal sometimes, especially if you have the type of sump with a ridge in the surface like mine. Tried using gasket sealant and it still leaks slightly.
As soon as i get my 9a its going.
windage sump?
sorry to be a dumb ass whats a windage sump/tray any advantages?
filter housing gasket
hi all the gasket was still availble from vw its the same as the mk2
still need help with the sump though…
