oil leak need help
(In Topic #121825)
oil leak need help
1st i have an oil leak were the filter houseing goes on to the block anyone know were i can get a new gasket?
2nd another oil leak… the sump nut at some time has been over tightend and damaged the thread is there anyway of repairing it or is it a new sump?
2) new sump is about £30 tops so be easier and cheaper to just fit a new one and be done with it
The rubber around the edge is harder/stiffer than a regular gasket and it can be a problem to get it to seal sometimes, especially if you have the type of sump with a ridge in the surface like mine. Tried using gasket sealant and it still leaks slightly.
As soon as i get my 9a its going.
windage sump?
filter housing gasket
still need help with the sump though…
