oil from base of disptick guide
(In Topic #122908)
I have a small oil leak from the base of the dipstick guide where it fits into the block. how does the tube fit into the block? is it just a push fit or threaded, welded??
would there be enough pressure in the system to force oil through this area and is it a worry? suppose it is very close to the oil pump.
what is the best fix for this, cant get mole rips on it without crushing the tube?
any ideas??
Ben
any ideas??
Ben
I took this off as part of my engine rebuild. It's basically tapered splines mate.. very tight fit. I wouldn't use pliers etc just grab it and force it in. It may just not be put in correctly.
