Oil Cooler Union Sizes
(In Topic #214875)
Hello All,
Hoping someone can put me in the right direction
I seem to have thrown away my threaded union/ inserts for my oil cooler, old style w/ little radiator
Can anyone show me where to order new ones ? (049 117 233) Or what size to buy ? I assume parallel thread style?
Not my pic, but the best i've found to show what i'm after, the insert that the oil lines connect to -
Cheers,
Adam.
Cheers,
Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
Anyone
Scirocco forum said a 16mm parallel threaded bar works?
Anyone convert that to some form of aeroquip/ motec fitting size
'83 MK1 Golf GTI
From what i remember for looking at converting my golf to use a motec oil cooler is that the fitting connection to the oil hose is a VAG only connection and not a standardized connection type, but if it helps I've managed to find out that the Audi 80&90 use the same fitting on their oil coolers as the MK1 golf. I had better luck searching 049117233 rather than 049 117 233.
Thanks for the reply, I got it sorted in the end. Forgot to update this topic!
They were a standard-ish item, i.e. you can buy them, although not from VW direct. I seem to remember one side is imperial and one metric, hence relatively hard to find on a standard shelf.
I've completely forgotten their sizes, however I ended up going into my local Pirtek shop.. Within a few seconds took a guess, and told me exactly what was needed!
Less than £5 each I think.
Sent from my Pixel 2 using Tapatalk
'83 MK1 Golf GTI
Great to hear pal, if you remember what size they are post another reply up on this for future reference to anyone else needing to know
