oil and water mixing
(In Topic #108088)
i got oil in the water on my golf mk1 gti how do i tell if its the gasket or oil cooler the car was running fine before
If so, then you can do a cylinder leakdown test to check if its a blown head gasket. If its not then it will be a faulty oil-water cooler.
it has a oil water cooler 2 pipes going into cooler above filter how do i do the test you said about
thanks ade
Another way, not 100% but DIY-able, is to do a compression check on the cylinders. You can get a compression tester from Gunson for around ?10-15 or thereabouts.
no its a bit more than condensation all the water hoses are filled with the stuff and its vary messey even rad is blocked
Have you checked to see if there is water in the oil? Water in the oil is the most common as the water is under pressure and a small crack or defect will most times only let the water under pressure through. Oil in the water could mean the defect is rather large and I would expect to fnd water in the oil also.
there is no water in the oil at all i was told it could be the oil cooler
