Non starter
(In Topic #152794)
Fuel Pump issues
Highwaystar said
I would not have put it in water. Sounds like it was dead before it went for a bath anyway. What I did to check the pump was getting power was to make myself a test bulb. Two bits of wire and a bulb,you get the idea. Once you have tested your new bit of kit on the battery move to the wiring for the pump,under the car rear axle. Connect it up and turn on ignition. My guess it will light up.
If it lights up you need a pump
Ps don't know if relay 15 has anything to do with pump just that it is related to fueling. Good luck
