no starty
(In Topic #119950)
no starty
og t a 86' GTi cab, its the stock engine 1.8 8v, k jet engine, the problem started last friday, i drove it the 22 miles to work fine, then when i went to start it for the trip home nothing… it turns over like a good un… i then got a mate to tow start me, and it did fire eventually, but it was rough running, no idling and only turning over above 3/4k but with no power at all at any revs when in gear.]
at first i thought it was igntion realated, a dead coil, or on its way out, needing all 14v of power to give a go enough spark, as the old coil was the only questionable part ont he igntion system, now ive replaced that with a known good coil… and nothing….
so the the ignition system is perfect, everthings new/in good nick, ive pulled all the plugs and its got a good spark, the king lead sparkign fine, so the coild in good nick etc..
next has to be fueling…. i cant actually smell fuel in the engine bay, which after 25mins of cold cranking you should really!!
the fuel pump is making its usual wurring noises from under the rear seat, and the relay in the fuse board is clicking as usual…. the fuel is getting to the fuel filter, and under pressure as ive undo the outlets banjo bolt and it spayed fuel out under pressure… next i pulled a injector and cranked the engine, no fuel came out, which i thought was wrong… so the problem has to be the metering head??
anyone ever had any issues like this… ive seen afew threads saying adjust the metering head, which ill have ago at if anyone had a good thread? ill also try and pull it up and pull a injector, to see if it chucks out any fuel??
ill be chucking some easi start down the inlet tomorow to see if it go at all, then proberbly spray some fuel down the plugs and try that… it has to be fueling?!?
any info would be great!
alex.
any more tips?
alex.
so it has to be fueling, now i was under the impression with the injectors removed and resting on the rocker cover, when turning over the engine, with the throttle open, it should spray fuel out of each injectors but nothing… nada!!
now ive undone the banjo bolts that connect the stainless braid hoses to the injectors to the fuel distributor, and when pulling up on the air flow senesor plate fuel does leak out of the fuel distirbutor,
it also is getting presure to/from the fuel filter, but possibly not enough….
that would also be the answer to why the injectors arnt firing any fuel out!
other than chanign the pump whats next?
alex.
anyone in the north west got a fuel pressure guage so i can defiantly check it is the pump? or know of any good specialists?
im pritty sure its not the accumulator, as its never had any hot start problems…
any help would be great!
alex.
my fuel pump is working, ive bought a 2nd hand one off here to try, hopefully this will sort it.
the reason i think its the pump rather than the injectors is 4 injecotrs wont fail at the same time…. i hope!
alex.
but its still not going…. now it kinda has to be ignition…. i guess…
the dissy's not moved, the coil, cap, leads, rota arm and plugs are all new, well less than 4 months old.
its possible its flooded now…. so ive left the plugs out over night, ill be going back in the morning to have on last go at firing it… if it doesnt got it getting set on fire.
alex.
ill be taking my compression tester down there too,
its got everything, fuel, air and spark. think its just given up all hope.
cheers for your help!
tunrs out that it was a bad coil, and heavily flooded!!
called the AA out and the dude said even tho its a new 'known' to be good coil… its still giving a weak spark, it was getting a good 12v to the coil… so it had to be that… he pulled the plugs dryed em out and after about 5 times it fired up, was idiling pritty rough, but ive bought a new coil for it now and its 100%!!!
funny thing is ive posted the same questions over on a aircooled forum VZi, and the title to that thread was…..
'think i know it…. bad coil'
lol
well 3 coils later, only one brand new one… its fine again. no probs with the metering head at all… wooops.
cheers for all your help
