No idle
(In Topic #74098)
No idle
took the golf for its first proper run down too newquay this weekend and it went like a dream! Mr Matthews little rocker cover trick has stopped the smoking and it didnt use a drop of coolant so no problem with the head.
But i have realised there is no idle!! well not when its cold anyway
once the engine warms up its ok.
When i start it up the revs go up to 1300-1400 then slowly drop but they dont stop. they just keep on dropping untill it stalls.
So what controls the idle when cold and (Rich) how much?
Steve
No Idle
What was the 'Rocker cover' trick!!
TC
Steve Matthews kept pointing out that there is a filter in the rocker cover whick gets clogged up so i tried it and voila no more smoke
the filter was causing oil to run down the pipes into the air box totally clogging up the filter.
Steve
took the spark plug out of No.1 and it was white
found a long allen key and turned the mixture screw till the spark got to a nice blue colour but now the fast tickover is about 1500 with the idle screw in as far as it will go.
is there another way of getting the idle down or do i have the mixture too rich?
any ideas?
Steve
the pipe that goes round the back of the manifold (to the AAV i think)
has been rubbing on the clutch cable and has a HUGE split in it!
Steve
Steve
