no fuel being delivered to the injectors.
(In Topic #126237)
could it be the relay? can any one shed any light on this for me. :? :dontknow:
it should be a cone shape if any trickle juice or nothing comes out there bloked.
buy new or decent secound hand that you know came off a runing car,new ones are around £40 each.dont skimp get new ones but before you fire her up you better replace the petrol tank as this is where the sediment comes from and dont forget put new fuel filter on the same time and she will run bet you.
you should hear a faint buzzing noise under the car fuel pump priming if not check fuel relay.
hope this helps if it does buy me a beer some time.
i should of made it clearer, i have removed the injectors from the engine and removed the nozzles from the braided hose's ,turn the engine over, i have fuel being delivered to the cold start injector and everywher else but no fuel going through the 4 braided fuel hoses,
will definatley change the filter this weekend though.
any ideas are appreciated
If that doesn't do it, then there will be a big problem at the fuel distributor section and it's time for a new fuel distributor/airbox.
I had a similar problem when I bought a GTi that had stood for about 5 years. There was no fuel coming out of the injectors. Lifting the metering plate however gave them fuel as has already been sugested. After much battling I eventually found that the inlet manifold gasket wasnt sealing, thus allowing the system to suck air instead of creating a vacuum which would lift the plate. A new gasket immediately sorted out the problem. So you may want to check the system for leaks stopping the creation of a good vacuum on the inlet side.
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
