my mk1 gti cab cuts out help :cry: HELP HELP HELP
(In Topic #84219)
Good luck !
Mark
Normally fuel filler neck rusty.
Entire system needs to be flushed and the contamination sorted, new filler neck?
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
Check the fusebox above the passenger footwell. Can't remember which one the fuel pump relay (poss no 13) is but pull out each fuse and check for any signs of burning/melting - try not to pull any wires out of the back. Same thing happended to me as it did to Mark - new relay (and fusebox) and everything was sorted. If there's no sign of damage there, try sticking a small magnet in the fuel tank (access under rear seats), if you get any debris on the end its probably rust from the filler neck which is clogging up the fuel pipes as Dubstar said.
A good idea would be to search through the Big Block Injection Engines section and you'll find plenty of tips there for your problems.
Lastly, stick a post in the new folks section and tell us about yourself + the all important pictures!
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
