More starting problems
(In Topic #82939)
Basically, when the engine has warmed up and I turn off the ignition it won't turn over unless the engine has properly cooled.
I have changed the starter, bearing, and battery but still the problem persists. I don't think it's a problem with the ignition switch as there apears to a current draw as I engage the starter and it starts first time every time when cold.
Help…… Please…… Anyone????
Do you get any heating problems?
As in the heating gauge being higher than normal?
Have you checked the warm up regulator?
See if she cranks up.
It's really p*ssing me off, just can't trust it.
I aint got a system anymore but the wires were just shoved in where the stereo use to go. I saw some bare wires that must have been touching here and there so i made them safe.
Also the loom from the alternator to battery was cut and re joined!(by a shabby mechanic). I have also sorted that out too so in the morning will check any other wires that maybe loose or touching anywhere and then re attach the new battery and see what happens innit.
Its driving me crazy as i have spent too much on the car!
I have a very similar problem with my Mk1 Cabrio.
She runs really well, and shows no signs of overheating.
But after a good highway run, if I stop and switch off (eg to fill up), she WILL restart if I am pretty quick about it. But if I take my time and get a coffee or visit the restroom as well, (anything above 10 mins) then she WILL NOT start. Starter motor doesn't budge. Dash lights up and all, but nothing from the starter motor.
I have to wait 30-40 mins for the motor to cool completely (I can hurry it by lifting the bonnet). Then she's right as rain again.
Now, the funny thing is, this is the second car I have had with this problem. The first was a Beamer. In that case I spent a fortune on garage bills until one day when I was stuck, some guy smacked on the starter motor solenoid with a spanner and she came back to life. His theory was: she runs fine, no overheating, but when she stops, heat builds up under the bonnet, the solenoid plunger thingy heats up and sticks fast. I replaced the solenoid, and never had a problem again.
Now I have the Golf with the same problem, and the irony is, I can't get a mechanic here in Belgium to simply replace the darn solenoid, because they all have other ideas (which all cost me a fortune!).
I wish I was mechanically minded!
Regards,
Nick
1988 1.8 Cabrio
