Mk2 injectors
(In Topic #134143)
Mk2 injectors
Thanks,
luke
better off just buying the right ones, look for merc brass injectors on ebay they will fit straight in
Thanks,
Luke
these are the ones i went for, but they've doubled in price
http://cgi.ebay.co.uk/MERCEDES-BOSCH-INJECTOR-201-124-126-107-129-123-460-1-/200482317720
Do you reckon its worth spending the money and going for new or just getting existing ones cleaned? Mine don't look all the bad from the outside.
you can do your own injector test though, pull em out and sit them in 4 equally sized containers. bridge your pump relay so the pump runs constant, then lift the metering head flap manually fully open, then gradually release it back to rest. check the spray pattern is a ncie even cone on all 4, then disconnect pump relay bridge. next wipe the tips then watch em for a minute to make sure non of them drip. finally measure the volume delivered is the same for all 4.
if there is a problem on one, swap the injector with one of the others and repeat the test, if problem moves its injector, if not its the metering head or fuel line. if the volume isn't quite equal there is an adjustment you can make on the metering head to even it up
just make sure its a reasonably good bit of wire as it will need to take some load for a bit. nothing massive just dont go using tiny single strand crappy speaker wire or anything
yeah either take the top off the airbox and push it from underneath, or take rubber boot from the top and lift it from there. a magnet would help here as theres nothing really to grab onto from above.
spluke said
Sweet, I'm actually going to give this a go tonight or tomorrow night! Thanks for all the info, you managed to explain it pretty damn clearly to me, and i'm pretty dumb when it comes to this sort of thing!
Hi luke, I completed the prowler test on mine a few weeks ago.
Quite easy.. If your local you can borrow all my stuff .. (4 nescafe bottles and a fused switch)
I sent mine for cleaning and they came back spick and span. and much improved (I tested again before I put them back in) it cost me £46 (10 per injector plus 6 delivery)
The guy did explain to me that because they are mechanical the cleaning will improve but not always solve the problem
Tony
rubjonny said
you want to replace em as a set really!
Sorry to dig up an old post.
Are these injectors suitable for a late Mk1 Cab with a std DX lump?
Surely they are set up to give a higher flow seeing as they are suitable for mercs and ferrari's!
Regards
spud
1992 Sportline Cabriolet in Red
