mk1 gti not starting
(In Topic #78639)
so what can i check around the fuse box that i might of knocked an how can i test the fual pump? :dontknow:
thanks
Bridge fuel pump realy
When you turn ingnition, one turn, you should hear fuel pump run for a few seconds and the relay click. If not (and dont have a meter) try above, if pump still not running then its not getting power. You could try a temp feed from battery to check if fuel pump works at all.
Also I believe if there is no spark the fuel pump gets switched off for safety reasons. So could be coil related.
You say water in foot wells, check earths (loads near fuse box) and fuse box for water damage.
Good luck
Cussco
