MK1 ENGINE PROBLEM
(In Topic #104026)
MK1 ENGINE PROBLEM
Does any one know whats happening. :? :?
Blocked tank vent
Warm up regulator
Fuel pump
I'd start first by running the car until it dies then take of the fuel cap and see if it starts. If it does Ok for a while again the the vent is blocked.
Otherwise it's a case of testing the fuel system and control pressures to see what's happening.
Rich
Has it had a recent service? If not you may want to consider changing rotor arm, dizzy cap and plugs. As well as air, fuel and oil filters.
Let us know how you get on and if you're still having problems.
