Mk1 Cabby - Stater Problem - Cabby Auto 1800 1990
(In Topic #151932)
Symptom is starter does not turn over. Solenoid does not clunk.
Initially this would happen periodically with not logical pattern but now it will not start at all.
On turning key I can hear a relay clicking but the solenoid on the starter does not clunk.
Have tried with another battery on jump leads but no good.
Have taken off the heat sheild to reveal the connections on the starter solenoid and all appears well.
What is the next logical stage of diagnosis please.
1991 Golf Clipper Convertable
1800 Auto
1800 Auto
1800 Auto
1800 Auto
I had a simliar problem, and did a write up here is the links:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=findpost&id=1220039#post_1220039
If you want the PSD Boot Sticker file, it's here: Boot Sticker
OK. This is my plan of action. I am going to disconnect the spade connector to the solenoid. I am then going to disconnect the main connections and connect in a hefty slave positive and negative, I am then going to touch the other ends of the slave to a battery and see if the motor turns over. Is this your recommendation?
1800 Auto
1800 Auto
haysy02 said
Just disconnect the spade connector. If your positive you have a good feed to the other connection, the just use a thick wire to create a bridge. Starter should initiate then. The write up mentioned above is brilliant as well. :-)
What do you mean exactly by "create a bridge"
1800 Auto
1800 Auto
1800 Auto
1800 Auto
Your not shorting it out to earth, you either bridge the large terminals, by-passing the solinoid, or put a feed to the smaller wire, which is the ign switch feed to the starter, as opposed to the battery feed.
If you read the write up I sent, you will see from the pictures you can by pass the smaller solinoid wire without having to remove the starter.
I would do that first to see if you get any life out of the old girl first.
1. Confirmed +ve feed to big chunky connector on solenoid.
2. Used slave lead and connected to spade connector on solenoid at one end and then - touched the other end on the +ve terminal on the battery - nothing.
3. Used a heavy shorting lead and bridged the 2 large solenoid terminals on the solenoid. starter spun up instantly.
So - does this mean the solenoid has had it?
1800 Auto
1800 Auto
Have you tried removing the solinoid and testing it off the starter?
It should just click in & out.
1800 Auto
1800 Auto
