mk1 1.8gti head gasket
(In Topic #74778)
if not, might be worth paying a pound or two more for peice of mind
hi mate
Don't cut the gasket it will be ruined and useless , your new head gasket should match the old one exactly - hole for hole- if not its the wrong one . Do not worry about hole sizes as long as they are the same . Crud in the holes over time can be caused by not running the car with the correct coolant / antifreeze [it prevents corrosion building up ] . Its worth cleaning the waterways while the heads off with a suitable brush and flushing the cooling system once when you have finished with clean water and then filling with the correct coolant mix .
Match the headgaskets up like for like and you will be fine [ take the old one to your supplier if in dought ] read the manual twice first though and the gasket swop will be quite easy . Good luck with it ………
also, since putting it all back together the car runs lovely except for after about 5 minutes of idling oil begins to seep out of the rocker cover onto the injection and exhuast manifolds, causing lots of smoke. i've tried refitting the rocker gasket again, but the same. the replacement rocker gasket is a cork one, so was wondering if by putting sealant in there too i may be preventing it from sealing propertly with the cover?? any suggestions??
