Mixture Screw seized
(In Topic #120957)
you can take the air flap assembly apart, its fiddly but doable. once you get the arm out you can then get some mole grots on the screw to gently crack it loose, if buffing it with a wire brush and penatrating oil doesnt help
When I got my Golf I thought it was running a bit rich, but in fact it was lean. The ignition timing was also out (too advanced) and the cam timing was wrong too - out by 1 tooth so retarding it slightly.
Not trying to worry you, but now those 3 things are sorted it runs a lot more smoothly, pulls more strongly, especially at low revs and idles nicely too, when it was a bit rough before. In short it has transformed it!
It doesn't take long to check with the right tools so might be better to get a garage with the right kit to make the checks for you (although you can check the cam timing easily enough yourself - there will be a thread somewhere on how to do it)
Hope this helps
The emissions check for the MoT is effectively the same as the check you would do to check your mixture - if your MoT is due soon then maybe get them to check and set up at the same time if necessary?
An ignition timing light is about a tenner on Amazon - instructions on how to check in the Haynes manual so you might want to have a look at this. Also make sure all of your thin vacuum pipes from the inlet manifold to the distributor are connected and sealing properly. It'll affect the running if they are not (you check the timing with the vacuum pipe disconnected from the distributor and blanked off)
