miss fire under load.
(In Topic #79119)
thanks peeps.
Jay
Anything else just isnt worth driving.
Life Member
have you tried swapping the HT leads? I had the same problem a few months ago and it sorte the problem straight away.
dan
Check filters and filter in pump… Loads about this recently if you do a search on the forum…
My Build Thread
J
muttley racing ftmfw
cheers guys
It's ignition related, how could a fuel problem cause a misfire?
http://www.vwgolfmk1.o…k+plugs+dizzy+cap&start=0
Read this post where I get it completely wrong!
Peter.
1980 1600 GTI, daily driver.
it could be that the ignition leads are breaking down, have you checked the colour of the plugs ?
has it happened all of a sudden or have you changed anything that may have had an effect on it ?
Stu
www.msportcam.co.uk
Peter.
Easily. Especially if an injector isn't flowing right (fuel distributor or injector problem). You get a very annoying lean miss on one or more cyls.
#NAME?
scirocco81 said
Peter.
Yep - And who actually diagnosed this as an ignition problem… :wink:
If you haven't got any fuel to ignite, then technically, you have an ignition problem I guess, so you could be right!
My Build Thread
