Misfire, ropey running & cutting out issues...
(In Topic #123357)
I changed the radiator fan yesterday and whilst I was in there notice there was a hole in the foam part of the intake pipe> I gaffer taped this up and took the car for a test drive and all went well.
(I did notice that there was a lot of oil on the intake pipe from an oil leak I had a while back, and thought it may have got in the hole- however the air filter should have picked this up).
Anyway, this morning when I tried to start the car it was really rough sounding, like the mixture was too rich and when it did eventually start (under full throttle) it misfired from the exhaust and the air intake ends…
…came back this evening and took the air intake pipe off completely thinking perhaps taping it up had blocked the flow of air too much, and then took out the plugs and dried them off. Tried starting it and same as before, it chuggs away like it needs to clear it's throat, misfires and then cuts out. Smoke coming out the back and smell of petrol up front.
Any ideas? :dontknow:
Cheers,
Meenrod
1991 Mk1 Golf GTI Cabriolet Sportline
Meenrod
hope you get it sorted
1981 1600 gti was silver now mars red!!
<a href="golfsig.jpg picture by barty2 - Photobucket"><img src="http://i286.photobucket.com/albums/ll82/barty2/golfsig.jpg" border="0" alt="Photobucket"></a>
I'll look at top hall sender, what's the WUR?
Cheers,
Meenrod
Meenrod
the wur is down the front of the engine its the warm up regulator a block with an electrical plug and 2 fuel lines i stripped mine and all is good
phil
Cheers,
Meenrod
Meenrod
I'll look at the hall sender. Where is it?
Cheers,
Meenrod
Meenrod
Cheers,
Meenrod
Meenrod
Didn't realise how easily they come out when the engine isn't running and sucking them back into place.
Thanks for your advice.
Cheers,
Meenrod
Meenrod
