Lumpy - warm up valve
(In Topic #146655)
Had issues with my cab ever since i bought her.
runs rough most if not all the time and burns rich so much so i find it hard driving with the roof down.
Recent change of the filler neck as it did have a hole it so thats done.
Decided to disconnect the warm up valve and it runs like a dream now, only problem i have is it idles at 1500rpm.
Does this mean its deffo the warm up valve thats at fault?
Jonathan
Check your fuel pressure. When the wiring to the WUR is disconected, the fuel pressure wont go so high that it actually set to. (Since the pressure is supposed to get higher as the engine gets heated up). So, I guess your engine gets too much fuel…
I found this guide very helpful
The Bad Habit Rabbit - Volkswagen Rabbit Page - Fuel Pressure Gauge
Hope this helps!
Golf California Cabriolet 1.8 GL 1988
Jonathan
