lumpy lean running 1.6gti
(In Topic #108929)
Been trying to sort out a misfire problem for a while now car will start fine no worries but is really slow to rev up and sounds like it's missing all over the place
Had the plugs out the ends look very pale no soot no black deposits which suggests lean Running
New parts include
Fuel pump
Fuel relay
Fuel filter
Plugs
Leads
Cap
Rotor arm
Is the missing and farting related to lean fuel or ignition/ coil problems
Does anyone in the Farnham/ Guildford area know what's going and fancy an expenses paid trip to have a listen and look. I need to get the car to Cornwall and back in 4 weeks time for my wedding.
Please help!!! i
New parts include
Fuel pump
Fuel relay
Fuel filter
Plugs
Leads
Cap
Rotor arm
Please help!!! i
Poor bloke, I feel for you mate. I wish I knew the answer for you but I don't.
Did you already install those parts or are they waiting to be installed?
Have you a Haynes manual or anything?
Bump for you
Bump for you
Cameron
1977 Volkswagen Golf GLS Automatic
think it would be worth having a look in the fuel injection pages in the technical section on the left of the screen. it has some trouble shooting tips in there and tells you how to adjust the mixture etc. may also be worth checking your injectors to make sure there not blocked or something. i'm no expert on this sort of stuff but thats what i would do :wink:
Tom
Tom
The fuelling is adjusted using a long 3mm allen key on a recessed screw between the metering head and the rubber elbow for the air intake. Clockwise is richer, and anti-clockwise is leaner.
Does it run rough when it's hot as well as cold?
HTH
Rich
HTH
Rich
