lumpy idle
(In Topic #75765)
lumpy idle
ive first tried to adjust the throttle cable, to hold the idle but that didnt work now ive tried adjusting the screw ontop of the throttle bodie that also hasnt worked, so im kind of guessing there is an idle control vlave or simmilar wich is proberbly full of carbon or knackard, any tips???
also it does it when its warm and cold, so its notheing to do with anykid of anto choke,
one other thing the engine somthimes does, 1 in every 20 start ups it feels like my accelerator cable is 5cm to long ie if you floor it it takes ages for the engine to reach the kind of revs it should, this is pritty hard to describe but after 2/3 long hard revs it clears it up, any tips???
soon im going to be taking the head off to remeove some broken studs on my exhasust manifold so if any of these jobs can be done at the same time let me know, also on that topic its ok to re-use the smae head bolts isint it?
think it is!!
cheers for any help
alex
Peter.
1980 1600 GTI, daily driver.
need to tighen it one of these days anyway!
alex.
Because it aint charging the battery properly at tickover means less amps to your engine.
Just try it, it's only a ?5, 5 min job.
Let me know how it goes.
Peter.
Life Member
Another tip is to clean out the throttle body with carb cleaner and the air flap in the metering head. Check the flap is centered and free to move. DO NOT adjust anything in the metering head unless you know the procedure.
Rich
